Dad needed to put his vacation time in, we are booking.
Printable View
Looks like I'll be making this one.
Ha! Ha! Drew. :thrasher::thrasher::drum:
Well I will be coming this year with both of my 6 wheelers should be a great time
Brian, did you get that little low end stumble in the carb fixed on your Max? I was thinking of you when I had the same exact issue with my 18HP Vanguard that I swapped in my Attex 'Lil Truck. I ran half a can of Sea Foam through the tank after I cleaned the carb out and after about half a tank of fuel, the problem was gone and there's no low end stumble at all.
I'll be there for sure! Looking forward to seeing everyone!
It is running much better now that I have been riding the crap out of it still has a very little stumble I will give that a try I have a set of numbered drill bits I was going to try to drill the main jet to the next size up also because under full throttle the flex pipe will glow red so it seems a bit lean I have a extry main jet so if it is no good I can put the other jet in and be OK if I mess the other one up a. What do u think
Just to remind all those racers only about 8 weeks left to finish wrenching before race number 1.
are there class,s or a rule book ? thanks mark
