Has anybody tried using a motorcycle lift like the ones you ride onto to lift their 6x6. Looks like you could roll it under and lift it. Only problem I see might be getting to the pedal to jack it up.
I just use a pallet jack with a couple 2x6s screwed to each leg.
Yep, I just lay 4x4's on each side of the lift N drive em' on.
The HFT $180 unit works but you may need a floor jack with it as the platform is short
Acta non verba
Pallet jack here also. Can get them used cheap and really come in handy !
How high will a pallet jack lift it?
The height depends on the model. Standard ones will only raise up 6" or so but some raise up like a scissor lift and will lift 2-3'.
Mine go's about 8 to 9 " and that is great for moving the 6x6 around.
