Tires/tracks? Right now I removed the wooden outboard reciever off the back that was there when i bought it and brough it into work. I dropped it off with a friend who is a tool maker for a aerospace manufacturer. He does all the custom prototype development stuff for the military (apache-osprey you name it he helped make the first test bearings and components in the trans and drive system). Anyways I asked him to take it and make it out of some high grade aluminum, going to have either my last name or Bigfoot embossed in surface. I may go ahead and black oxide it first, but will see how much we can get away with on the job. I have been trying to see what trypes of upgrades i can do with the bearing/seals and i know we make seals the right size at one of our other factories..... now if only i can find some spares around. A real note we used to get close to cost on bearings hat we produce if we order them in house, so if I can find a Timken replacement I will let you all know. We do make that best bearings in the world, which is why they use the ones at our factory to go beyond earth and into space.
Hi Castro, would it be possible to get a few mor pics? I'd like to build a little more protection for my front end because I do a lot of fencing and sometimes make a lot of contact once in a while. Not by choice.
Greetings Castro, i realize you did this post a long, long time ago... Im hoping you are still active & can tell me where to find a brush gaurd similar to yours ? I have a 92/93 argo magnum 8x, all the gaurds i find online are the new style for the new machines... Thanks for any help i can get.
I found this in storage at a dealer. he had it sitting around for years. I can get more photos if you need. I was gone but now im back online more often
