argo 13" plastic track question.
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 45
Thread: argo 13" plastic track question.
Hybrid View
  1. #1
    Join Date
    Mar 2010
    Location
    innisfil,ontario
    Posts
    1,430
    so i dug my tracks out of the snow yesterday and got them thawed out.tried to loosen a set screw to break them but that was just not happening.cut the pins of with my dremmel and drove them out no problems.while looking at the the tracks you cant help but notice a lack of traction.but there does seem to be holes in the tracks to bolt on an ice cleate of some description.was wondering what you guys are using for a cleate or whether a nut and bolt would suffice?
    cheers
  2. #2
    Join Date
    Jul 2007
    Location
    Northern BC
    Posts
    2,990
    That would work fine. You could take it one step further and run a short piece of chain between the bolts on each segment. I don't think you would need V-bar chain, but it would be interesting. I also don't think you need a chain across every segment, maybe every 4th one or so.
  3. #3
    Join Date
    Mar 2010
    Location
    innisfil,ontario
    Posts
    1,430
    a v-bar chain would be incredible.im gonna put these on tomorrow the see how much clearance i have.thanks RD.
  4. #4
    Join Date
    Jan 2010
    Location
    Firth, Nebraska
    Posts
    42
    Ice cleats are available for the tracks. They are about 1 1/2" X 2" and are basically a u shaped metal with saw like edges. They bolt right on. I have them on my machine (plastic tracks) and they work pretty well. You can probably check Richs' relics on "Route 6X6" for pricing
    good luck
  5. #5
    Join Date
    Mar 2010
    Location
    innisfil,ontario
    Posts
    1,430
    Quote Originally Posted by TerryA View Post
    good luck
    did you get yours from richards relics?
  6. #6
    Join Date
    Jun 2007
    Location
    Buffalo, NY
    Posts
    6,442
    You might just want to contact Tru Tracx directly or maybe even Argo......you'd probably get the same thing, but for less money, this way.
    TRU TRAX HOME
  7. #7
    Let me know how it goes. I have a set of 13" tracks for my Conquest but didn't think I could run cleats, picks, or studs because with the narrow track there was a clearance issue with the tub. I haven't taken any actual measurements either. That was one of my projects for this winter. - Ozzy
  8. #8
    Join Date
    Mar 2010
    Location
    innisfil,ontario
    Posts
    1,430
    i have very little clearence as well.if i could get a look at a cleate it might be cheaper to make a bunch.
  9. #9
    Hi, Just a bit of a warning about cleats on the 13'' tracks. The tracks bounce in the middle and hit the under body. If there are cleats installed in the middle they will score the under body cut holes in it. The cleats wheather they are homemade or not have to clear the outside edge of the tub even then the tracks can also twist inward and hit the body. Hope this helps. Paul
  10. #10
    Join Date
    Jul 2007
    Location
    Northern BC
    Posts
    2,990
    I was looking at one machine that had Studs in the tracks, the owner had bolted strips of UHMW Plastic under the fenders to protect the tub. Seemed to be working for him. The strips of plastic were lined up just to the side of where the studs would have rubbed under the tub fenders.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
