Not sure where to post this one, but it's Argo related, so I'll try it here.
At room temp I have my brakes set up so I have a little slack before they engage. All good.
When I take it out, everything is fine untill the brake system heats up, then one brake tightens up untill there is no slack, and the brake is actually partially engaged. Then I have to stop and loosen that brake off.
Once I get home, and park the Argo, it cools off, and when I get in for the next ride, THAT brake is so slack that it it drops away from the dash 4-5 times as far as the other brake before it will engage.
So, is this a fluid problem, or an O-ring problem, or........?
