+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: Centaur opinions
  1. #11
    North Country Tough's Avatar
    North Country Tough is offline 6x6 World Sponsor North Country Tough is on a distinguished road
    Join Date
    Oct 2011
    Location
    Southern Ontario
    Posts
    687
    Quote Originally Posted by SiliconTi View Post
    I have heard that they do not like deep water. If your needs require deep water crossings, it may not be the machine for you. They do look cool though.
    Hmmm yes water crossing is a must for my purpose,have to give this some thought,would have liked the tougher machine than the Avenger for pulling a snow trail groomer.
    I started six wheelin when Moby Dick was a minnow,what I lack in talent I make up for with more tires
  2. #12
    Robinhood02's Avatar
    Robinhood02 is offline Crackpot Cruiser Robinhood02 is on a distinguished road
    Join Date
    Aug 2008
    Location
    High Level ,AB , Canada
    Posts
    373
    when i was talkin to the fellow that owns this Centaur he said that Argo has lost their amphibious status on the Centaur because of too many sinkings carrying even a small load, i think they are probably pretty heavy for the displacement of the tub concidering the steel cab and top frame, maybe if one went to the trouble of replacing the steel cab with an all aluminum cab maybe they would be truely amphibious again
    He who has not cruised the back country in a 6x6 , has not lived life to it's fullest
  3. #13
    spankbomb is offline Registered Rider spankbomb is on a distinguished road
    Join Date
    Mar 2011
    Posts
    11
    Correct, the Centaur is not an amphib.
  4. #14
    philipatmaxfour's Avatar
    philipatmaxfour is offline Master Mudder philipatmaxfour is on a distinguished road
    Join Date
    Jun 2007
    Location
    Ontario-Prince Edward County
    Posts
    413
    would mounting duallies on 1 or 2 axles help it float?
  5. #15
    glen1971's Avatar
    glen1971 is offline Sophomore Slider glen1971 is on a distinguished road
    Join Date
    Aug 2009
    Location
    Pincher Creek, Alberta
    Posts
    59
    A word of caution on a Centaur though.. Make sure you aren't getting something that was owned by an oil and gas or utility company that has been bagged.. Quite a few companies use them but they don't realize the extra maintenance that goes along with some pieces of equipment.. One company down here was going to sell their old one for $10K (I think).. They had to send it back to Argo for repairs as it was leaking diesel and they couldn't figure out why.. When they had a mechanic look at it, they found a drive chain broke and had hit the tank.. They used to do donuts with it in the winter to see if it could...
    I heard from the guys that used to run it that it would float like a crowbar, because they added a square tubing storage box to the back of it...
    Do your research and make sure it is the right machine for your needs and that the past owner did some up keep on it..
  6. #16
    dickdl is offline Sophomore Slider dickdl is on a distinguished road
    Join Date
    Mar 2011
    Location
    Ohio
    Posts
    31
    I you don't want it, PM me. I am interested.
  7. #17
    Argo guy's Avatar
    Argo guy is offline Sophomore Slider Argo guy is on a distinguished road
    Join Date
    Feb 2011
    Location
    Canada
    Posts
    32
    The Centaurs are very, very tough and very reliable machines. They run a 3 cyl DAIHATSU aka ( Briggs and stratton ) Diesel engine with and without a turbo ... you can even get them with a gas engine but I wouldn't suggest getting that. They run #80HD chains and I have never seen one break yet. They are able to pull 10km of hydro line with no problems at all. Anything else you want to know just let me know
  8. #18
    spookum's Avatar
    spookum is offline Master Mudder spookum is on a distinguished road
    Join Date
    May 2011
    Posts
    607
    I think i have a thread some where that i prove that a 22X11X8 tire makes 130 LBS of floation... times eight i REALLY beleive that you can make a centar float. (16 tires totoal.... i think that they ALMOST float with 8 tires on them but dont drive it into a lake unless your sure)
  9. #19
    Argo guy's Avatar
    Join Date
    Feb 2011
    Location
    Canada
    Posts
    32
    I cannot tell a lie I was told by an Argo rep that the Centaurs do float stock from the factory but they DO NOT and WILL NOT tell the general public this information only because this machine wasnt designed to float across a river ... i was designed to push it way through swampy areas
  10. #20
    mudbug3 is offline amphib fanatic mudbug3 is on a distinguished road
    Join Date
    Jul 2007
    Location
    I live in Shreveport,,Louisiana
    Posts
    3,169
    The Argo rep told you correct. Here is a video proving that a Centaur 8x8 ------> WILL FLOAT.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
