+ Reply to Thread
Results 1 to 5 of 5
Thread: Sealing the tub
  1. #1
    pcs800's Avatar
    pcs800 is offline Sophomore Slider pcs800 is on a distinguished road
    Join Date
    Aug 2011
    Location
    Michigan
    Posts
    62
    Sealing the tub
    What is the best thing to use to seal the bolt holes, axle holes, etc when putting an argo back together? There's some kind of black rubber between the body and bolt washers now.
  2. #2
    coosaridgerider's Avatar
    coosaridgerider is offline WHEELIN AND DEALING coosaridgerider is on a distinguished road
    Join Date
    Mar 2009
    Location
    Alabama the Beautiful
    Posts
    931
    I use np1 made by basf, you can get it at any roofing supply co or fastener co. This caulking works great on just about anything.I use it on everything,even my tires to help seal the bead.you can get it in a variety of colors.
  3. #3
    Dan67's Avatar
    Dan67 is offline 6x6 World Sponsor Dan67 is on a distinguished road
    Join Date
    Mar 2010
    Location
    Oconee County, SC
    Posts
    568
    I did a complete bearing change on my Conquest and I ordered new cork gaskets from a dealer. Everything sealed up good, no leaks.
    Argo Conquest 8x8
    Hustler 980
  4. #4
    Join Date
    Mar 2009
    Location
    Posts
    931
    Tsc has the cork gasket material in fairly large pieces if you want to save some $ and make your own.
  5. #5
    pcs800's Avatar
    Join Date
    Aug 2011
    Location
    Michigan
    Posts
    62
    Seems like the sealer would form a more water tight bond than cork, or am I wrong?
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
