Hi,
I have been a member for quite sometime, but basically just reading. I have a 23 hp Vanguard engine i would like to put in my 6x6 Argo Vanguard replacing the original 16 hp. I run 18" tracks in the winter and am hoping i will get a little more torque from this engine for the hills while pulling firewood. From the reading i have been doing i still have a couple of questions. Maybe someone can offer advice.
1. Mounting, are the bases the same? Do you use the same holes?
2. Engine clutch, will my original clutch require any adjustment? Alignment?
3. Exhaust, can i use the 16 hp exhaust with a modified manifold from the 23 hp?
Thanks
Newfieguy
