just one quick question. when you have tracks on how do you grease wheel bearings?
I drop my tracks after every other ride to grease mine
Yes I don't think there is a way, I think you must separate the tracks
"Argo 8x8's only" type of guy
"old school Argo expert"
I think the newer models have a hole in the rims and hubs that you can grease thru, just got to raise the machine so you can rotate the tires to get to each grease fitting
I like to take my tracks off and check bearing play. That way you can grease and check for bearing/axle wear. I'm running the 18" rubber tracks onnan hdi.
I need to consider doing the track off thing. I spent was to much time trying to get the center inside. There are holes in the rim but not in the flange. ???
I have thought about drilling my flanges
I was thinking of that to about 8am after spending WAYYYY to long to get that center.
I'll have a slide on side ways grease fitting before the sunsets tomorrow for sure
I did mine last time with the tracks on.. What a pain in the butt!! If you had a second elbow that was like a universal socket adapter and with 6" biceps, it wouldn't be a problem... I'm thinkin for the extra half an hour, I'll be pullin the tracks off..
