try a bearing puler
try a bearing puler
These are all some interesting ideas and I should put a few to the test. I'm thinking the chain is the easiest. I have a feeling removing the left side will be just as hard on this machine as the right, so I have not bothered down that road but I was thinking that too.
Would you have a suggestion or a pic of the slide hammer idea? Seems like the most orthodox way to do this removal properly (without pulling the power pack).
Thanks guys for all the suggestions. Definitely don't want to cut it all out, as I know that is an option but just not the right one for now. I'm still not that frustrated as of now. lol
A slide hammer is simple to make. You need a piece of good steel plate drilled to fit over the wheel studs, in the centre of that plate weld a 2' length of something like 1/2" bar, get a good heavy hunk of steel with a hole in the middle that will slide over the 1/2" bar. Slide the lump of steel over the bar and weld a SUBSTANTIAL stop to the bar (the opposite end to the piece of plate with the wheel holes in)
You bolt it all to the wheel flange with the wheel nuts, slide the heavy lump of steel down the 1/2" bar to the wheel flange and then whack it back to the stop on the other end of the bar. Mind your fingers, I'm no doctor but I know it WILL hurt if you get them trapped.
A good solid slide hammer is capable of ripping the frame apart so take care.
Be careful it is not unheard of to pull the studs out of the flange ,,,,, brute strength can get $$$$$ ,,,,don't ask How I know ....
For the cost of the bearing of about $35. Just take a long punch.and hammer, hit the outer race in a couple of spots and she will fall apart. take a screwdriver and remove the balls. Then you should be able to just pull the axle out. Its a lot quicker. Far less hassle.
I had a really stuck front axle in my conquest when I did a complete bearing change. I went out and bought a slide hammer just like the one on the right in Rockdoc pic. Three hits and it was out. Oh and wear a good leather glove on your hand that is slamming the weighted grip. I got my slide hammer kit for $75.
The best way I've found, and I have several slide hammers, is to buy a cheap air chisel gun (WalMart has them) and cut the pointed one off flat and start banging inside the hub. The sharp continuous rap will loosen the worst of them. Of course I'm assuming you have air, if not, slide hammer gets it done.
