I just changed the small plastic fuel filter (not the large metal one after the pump) on my 2009 Avenger 750EFI and after putting the new one on the pump does not seem to be able to bring fuel thru the filter and on-wards into the pump and to the engine.
After replacing the filter i turned the key to the run position for a good 30 seconds without cranking and heard the pump but no fuel was visible thru the new clear filter. I then started the engine and it ran until fuel ran dry from the lines after the pump I guess.
Do I need to prime the system some how after replacing this filter???
Would appreciate your help with this.
