Checking inner bearings
+ Reply to Thread
Results 1 to 5 of 5
Thread: Checking inner bearings
  1. #1
    Hi,
    I'm in the process of changing out a couple outer bearings with HD ones from Adair. My question is how do you guys tell if the inner bearings need replacing? Or is it better to change them both at the same time? Any help would be greatly appreciated.
    Thanks
    Chris
  2. #2
    Join Date
    Dec 2011
    Location
    west coast B.C.
    Posts
    312
    Inner bearings do last a little longer then the outer. But for peace of mind, just change it, you have it all apart anyway. Then you know what you have.
  3. #3
    Join Date
    Jul 2007
    Location
    Northern BC
    Posts
    2,990
    If you're unsure, then change them, but doing a Lift Check on the axles will expose bad bearings on the inner or outer bearing,
    I get about 3-4 times more life from the Inner bearings compared to the Outer Bearings.
    Thanks guys, I think I'll just change them out. What is an average to get out of inner/outer bearings when maintained properly? Or are there too many variables to come up with a consistent average? I have a 2007 avenger with the 18" rubber tracks
  5. #5
    Join Date
    Jul 2007
    Location
    Northern BC
    Posts
    2,990
    Too many variables, in my experience. Sometimes you get 10's of hours, sometimes you get hundreds of hours.
    What I will say is that 18" Rubber tracks eat bearings, tensioners, and chains, ect for lunch. You might consider Track Tuners for your machine if you run those tracks a lot.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
