2011 750 HDI high temps
+ Reply to Thread
Results 1 to 4 of 4
Thread: 2011 750 HDI high temps
  1. #1
    Unit was purchased used in the spring, I put ~60hrs on it this year already(310hrs total). So many places to see, so little time
    Issue is Radiator plugging with Fines/Tamarack needles, have to blow it out from Fan side after every use and then Shopvac Air intake housing. Its not uncommon to have to stop often to clean leaves off exterior screen. There are very few "groomed trails" where we Hunt Moose and Elk, just the way I like it. Keeps the Quad access down.
    Question, has anyone been running a pre screen before Radiator? I realize it can possibly cause air flow restriction, but I see a possible benefit with ease of cleaning fines before its in Radiator, cleaning exterior of rad just isn't enough sometimes.
    Unit is not overheating, just running hotter then normal under load. I typically see 3 bars under normal conditions, 4 bars Pulling Moose, I get belt slipping and hand brake fade off. I will flush brake with DOT5 if I can find any. Feet get pretty warm.
    We pulled a small Bull Moose out this morning, -2C last night so not warm, no belt slipping but hand brake fades. No need for a Heater
    Looking at install hood fan, but see it more as a bandaid
    Ever since I bought 2011 750HDI, seems everyone in town calls for help draggin moose/elk out of the bush. Setup to handle pretty much anything, Argos make it so much easier. I actually enjoy doing it
  2. #2
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    On my older Avenger, the Kohler motor had a pre-screen on the radiator. I don't think a fan on the hood is a bad idea either. Argo sells a hood / fan kit that you can purchase to help pull some of the hot air out of the engine compartment.
  3. #3
    Join Date
    Oct 2007
    Location
    Yellowknife, NWT, Canada
    Posts
    209
    We had the same issues this fall in the mountains. HDI brake fade on the HDI's and my (2005 avenger) steering fade. Talked to an Argo Distributor rep and they said the hood fan will likely fix that. He said they were seeing a 40 degree (Fahrenheit I assume) drop in engine compartment temps.
    I had one but have not installed it yet. No point right now in the NWT, I need all the heat I can get!
    Derek
  4. #4
    Join Date
    Jun 2007
    Location
    Ontario-Prince Edward County
    Posts
    997
    hi temps
    Quote Originally Posted by Mike View Post
    yes, My older avenger has a pre screen on the rad. Sometimes it gets covered with cat tails or whatever pretty quick.Its nice to just pull it up ,shake it off and go. Can;t beleive that Argo cancelled that. I would talk to a kohler dealer to see if you can maybe get one.
    The hood fan is prob. a good idea on the hdi machines
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
