Conquest Brake or Transmission issue?
+ Reply to Thread
Results 1 to 4 of 4
Thread: Conquest Brake or Transmission issue?
  1. #1
    Join Date
    Oct 2014
    Location
    Centralia, MO
    Posts
    15
    New owner here. 1998 Conquest. I just completed a bearing, seal and chain replacement. I also drained and cleaned the brakes. Replaced with Dot 5. I still have the wheels off and I started it up to see how things were working. Be fore I started the right brake was dragging really bad. When I took the calipers and master cylinder apart it was obvious that they were just gummed up. Now when I put it in gear only the right side turns. But if I brake right the left side will turn. If I brake both, nothing moves. The left side will creep if I rev the engine, in gear of course. So my question is do I have a tranny issue? I just bought this unit and it shows 103 hours. It is in very good shape. Any ideas?
    Thanks
    Jud
    1998 Argo Conquest
    1999 Jeep Wrangler on 35s
  2. #2
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    No.
  3. #3
    Join Date
    Nov 2009
    Location
    Charlotte, Mi/ Houghton Lake Mi
    Posts
    2,910
    The Argo trans is a simple open differential design. The easiest side to spin will get all the power while the other side gets none. To compensate a small amount of brake pressure has to be applied to the spinning side equaling them out. It will take a little time to learn this skill.
    Here is a couple videos and some discussion on the subject http://www.6x6world.com/forums/trans...vs-t-20-a.html
  4. #4
    Join Date
    Oct 2014
    Location
    Centralia, MO
    Posts
    15
    Thanks! The link was super helpful.
    1998 Argo Conquest
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
