Amphibioius Atvs Logo
Go Back   6x6 World > 6x6 ATVs > Argo ATVs
Argo ATVs Forum for discussing Argo ATVs from the Vanguard and Frontier 6x6 to the Response and Avenger 8x8!
Reply
  #1 (permalink)
Old 05-10-2008, 04:30 PM
cory_Alaska's Avatar
cory_Alaska cory_Alaska is offline
Alaskan Rider
cory_Alaska is on a distinguished road
Conquest Batt charging issue
Not sure whats going on with my new toy. The first time I took it out the Ammeter was showing that it was charging at just over 16 volts. I checked out my buddies avenger and his was just over 14 and most charging systems I am familiar with are also around there. So, I double checked it with a multimeter and sure enough, at full throttle it was topping 16 volts. Well, I ordered a new voltage regulator and I put it in yesterday and still the same story! What am I missing? Anyone else experience this?
  #2 (permalink)
Old 05-10-2008, 06:21 PM
tracmaster's Avatar
tracmaster tracmaster is offline
Sophomore Slider
tracmaster is on a distinguished road
Charge your battery then check again. my avenger has a 25 amp altenator..so i think 16 would be ok.
Tracmaster
  #3 (permalink)
Old 05-10-2008, 06:23 PM
tracmaster's Avatar
Sophomore Slider
Do you have a volt meter or amp meter??
  #4 (permalink)
Old 05-10-2008, 09:50 PM
Roger S's Avatar
Roger S Roger S is online now
ArgoNut
Roger S is on a distinguished road
16 volts is too high for a 12 volt charging system. I have no experience with the conquest.
__________________
  #5 (permalink)
Old 05-11-2008, 11:40 PM
Alaskan Rider
Quote:
Tracmaster
You are thinking amps, not volts. I have a volt meter and it is reading just over 16 volts at anything over half throttle. Just to double check and make sure the volt meter is working properly I used a fluke multimeter to double check and that is reading over 16 volts as well.
Quote:
That's my thinking as well, but I dont understand why a new voltage regulator would not solve the problem.
  #6 (permalink)
Old 05-13-2008, 06:53 AM
m350 m350 is offline
m350 is on a distinguished road
Hmmm on my 2000' BigFoot my volt meter reads just about 12 volts,when running,,,,Hammer down maybe 13 volts,,Battery is the same one I got it with,,,so far it has been fine. 16 Volts seems to much,,,seems to me,,13.9 or so volts is about all you want on most 12 volt systems.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
