Hey guys I just bought a new Argo 750 hdi in December and really like it. I do have a few questions tho. My battery was not very good from day one. If it is below -15 it dies really easy. If it's colder then -20 it won't even turn motor over. I charged it up a few times with same results shortly after. So I bought a new(different) battery today. Haven't tried it yet. This leads to my main question. Do many guys have starting issues? I find mine a bit finicky below zero. It usually starts fairly quick but then idols slow and dies. And then it's hard to start. With that factory battery I would only get a few attempts and then battery would die. If I give it a bit of gas and keep it running until warm then it works perfectly. Now what boggles me is on most efi systems you do not give it gas as the efi system normally works it's magic. I also had to give it gas while cranking at times to get it to fire which is also different from most efi systems. All my other efi toys will turn over all day and not fire if you are on the gas. I am going to install new battery in next day or so as it should help some. This Argo has the added alternator and heater. Does anyone have any advice for me? I was really hoping for better starting as my fiancé was planning on using Argo a bit for work. I would not send her out in the cold the way it's been so far. Other then starting issue while cold I really do like unit!
