2007 Response value please
+ Reply to Thread
Results 1 to 8 of 8
Thread: 2007 Response value please
  1. #1
    Hi folks any input on value it has under 200 hrs and incorrect cheap tires on it. I would really appreciate any reviews or negatives or pluses please. I'm currently riding an 2001 Big Foot which is a great low hr unit. Thinking 8 wheels and tracks would be better
  2. #2
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    402
    If it really is a 2007 than it is not a response or they have the year on the machine off. I think the response was discontinued around 2004ish. I would say that the response is not the ideal machine for track due to the low HP. If you are at low altitude and just running standard tracks for mud it should be fine, but also check to see what gear ratio the tranny is.
  3. #3
    Join Date
    Dec 2014
    Location
    Lake County, Ohio
    Posts
    58
    I believe 2007 was the last year manufactured -> Argo UTV Response 8x8
    Ken
    For Sale 2000 Max IV
  4. #4
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    402
    Quote Originally Posted by ken white View Post
    Oops, My mistake. Thanks for the correction.
  5. #5
    Join Date
    Mar 2010
    Location
    Oconee County, SC
    Posts
    823
    See if you can get the serial and model number from the seller, those can be cross referenced to determine the year it was made. 95-04 have the brake levers and 05-07 have t-bar. All have a briggs 18 hp engine. Rear bearing extensions were optional. (Looked at several response before I bought my conquest, and none had the rear extensions). If you are wanting a to put tracks on an 8x8, I'd avoid the response. Look for an avenger or a conquest.
  6. #6
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,049
    Been staying out as I've never owned or sold a response, if it has the G trans. and rear bearing extensions and tracks priced right I'd consider it. Keep in mind all Argo's seem to hold there value, even those under powered, yet keep on going.
    Always thought I'd like one though, specially a brown one ( with a 23).
  7. #7
    It's definitely a 2007 how do I know if it has a G transmission ? Do you know. I do know it's the T steering.
  8. #8
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    402
    It will have a GU, MU, or HU and then some numbers stamp on top of the tranny. The GU is low the MU is Medium and the HU is high.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
