I've noticed mine doesn't have a lever to change the angle. It has a big pin and 5 holes. Kind of a pain to change it.
That's how mine is. If I don't get a blower, I will probably fabricate an electric angle system.
Hey jlemon, I have the same setup, I used it to redo the front yard about 6 dump truck loads of soil and i use it to plow snow It does fine with just tires and I use it most the time in high gear.
If the snow gets to heavy...take littler bites ..but it should do great 90% the time.
Does yours have a wear bar and skids? Mine doesn't have adjustable skids but it looks like it has a wear bar with a piece of 1" pipe welded to the bottom.
I noticed a ticking sound from the chains when I first brought it home. I lubed all of them up and it didn't go away. I pulled the floor pans off and noticed both of the top tension pads were missing on the adjusters under the seat. I found one but the other is MIA. I also have the chains rubbing the frame in one spot. Guess I'll order new pads and a couple for over the frame. Looks like new chains this summer.
Mine has metal skids and wear bar.
