winter tune-up for my conquest
+ Reply to Thread
Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 11 to 20 of 36
Thread: winter tune-up for my conquest
  1. #11
    Join Date
    Jul 2009
    Location
    Cleveland,Oh.
    Posts
    1,589
    Here's a pic showing both.
    The original is 62mm O.D. the HDI is 72mm O.D. The HDI has the triple internal seal. The only significant difference between late model 1 1/4" axles and the HDI axles that I know of is the heavier flange for the wheel.
  2. #12
    Join Date
    Jun 2007
    Location
    Ontario-Prince Edward County
    Posts
    997
    Quote Originally Posted by JoeMeg View Post
    Yes, but with the grease hole in the new flange,it offers a straight in access to the" one only grease nipple" and on a new machine with the new drilled wheels it is easy to grease the outside bearings without having to remove your snow tracks or wheels. right?
  3. #13
    thanks guys for all the information!
    The adair upgrade kit sure looks great , what about the factory Argo kit part # 101-97 ?
    I am from Canada, it should be easier and cheaper to go with our local dealer.
  4. #14
    Join Date
    Oct 2010
    Location
    Wasilla, AK
    Posts
    923
    the 101-97 can be made to work on the center axles, but using a 1/4" thick adapter plate is much better. The kit from adair includes this (plus gaskets, bearing, carrier, flange, and length appropriate bolts w/rubber washers, nyloc nuts) and prevents you from having to enlargen the holes in your HDPE tub on the center axles. It also prevents you from having to completely remove your existing bearing extension (housings) from the corner of your machine, purchase newer style extensions, and install those simply so that they'll accept the larger HD bearing and carrier.
    Also, I like the idea of the larger surface area of the adapter plate fitting against your tub as well. This method also puts the HD bearing and bearing flange an additional 1/4" further out on the axle which is never a bad thing. Remove the axle paint with a wire wheel to a point just beyond where the HD bearing will ultimately rest before re-assembly. Makes everything go back together w/o any problems at all.
  5. #15
    Join Date
    Jul 2009
    Location
    Cleveland,Oh.
    Posts
    1,589
    Quote Originally Posted by philipatmaxfour View Post
    Ahha,thanks to this awesome forum,I now know of TWO significant differences between the late model axles and the newer HDI one's. Thanks Warren!
  6. #16
    Join Date
    Oct 2008
    Location
    Thornton, CO
    Posts
    646
    ... it is easy to grease the outside bearings without having to remove your snow tracks or wheels. right?
    If you are using the Argo extensions they will cover the hole. If you forget to line up the hole when you install the tire then it also isn't so easy - well, that's what I heard.
  7. #17
    Join Date
    Sep 2013
    Location
    Waldo Wi
    Posts
    941
  8. #18
    Join Date
    Oct 2010
    Location
    Wasilla, AK
    Posts
    923
    Glad I'm not the only one who's forgotten to line up the grease holes. Not much motivation to do it once the tracks are on
    Biggest benefit is on the corner axles where the bearing extensions tuck the outer bearings nicely behind the wheels. Virtually impossible to grease without removing the wheels. HD upgrades here are super nice.
    Center axles though can be greased w/o too much of a problem with or without HD upgrades and drilled holes. You will have to get your arms a little dirty though.
  9. #19
    Join Date
    Jun 2007
    Location
    Posts
    997
    Winter tune up
    Quote Originally Posted by JohnF View Post
    Yup! John you are right.I forgot that I am using Bolduc tracks and spacers. They look very similar to the pics. that I have seen of Adair track tuner spacers except the bolducs don't spin. I wonder if adair sells spacers for the outside wheels that have the "notched" style design? I am often wrong
  10. #20
    I found this link for the Argo HDI bearing upgrade :
    Parts Bulletin #161
    http://www.google.ca/url?sa=t&rct=j&...,d.eXY&cad=rja
    Is there anyone here who did the 3 cork gasket thing ? It looks weird too add so much soft gasket there ?
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
