Changing brake pads
+ Reply to Thread
Results 1 to 2 of 2
Thread: Changing brake pads
  1. #1
    Changing brake pads
    I have a 2001 Bigfoot. Is it possible to change the brake pads without taking the calipers off the mount. Will the old ones slip out once the cotter pins have been removed and the new ones slip back in?
  2. #2
    Join Date
    May 2010
    Location
    Fairbanks AK
    Posts
    1,456
    Yes they are easy. Push one piston back at a time with the old pad then pull it out and install the new one.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
