Intro to Argo
+ Reply to Thread
Results 1 to 8 of 8
Thread: Intro to Argo
  1. #1
    Intro to Argo
    I am looking into purchasing a 2000 6x6 Argo and have a few questions about them. I love right next to a creek that runs pretty hard at certain times of the year. Can the Argo handle moving water or does it have to be stagnant?
  2. #2
    Join Date
    Feb 2014
    Location
    Central Saskatchewan Canada
    Posts
    171
    Moving water=very bad situation. Depending how fast and deep the water a gas or electric trolling motor can be used.
  3. #3
    Thanks for your help. How are they in gumbo mud?
  4. #4
    Join Date
    Jun 2007
    Location
    Ontario-Prince Edward County
    Posts
    997
    Quote Originally Posted by kareed21 View Post
    Stagnant??? That sounds like very still water!There are lots of videos of Argos in water on this site. You should look at some of them and judge for yourself. 8 wheel machines feel much more stable than the six wheel ones but once you get used to being in the water they are stable too. The newer Argo tires are faster in the water and larger 12 inch tires offer more flotation than smaller ones. There are many types of mud,and some members on this site have tried to travel in many of them, usually with success.
  5. #5
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Wasn't going to reply at first however we'd hate to see you disappointed or hurt, you will probably be impressed if you're currently 3 or 4 wheelin or walking.
    If the mud you're looking to ride in is tidal or silty you'll probably get stuck and belly out, tracks will help tremendously though they are NOT a cure all.
    I have been in a "hard" running creek with run off feeding it and it was a chore to cross ending up nowheres near I wanted to be (read far down creek) and was treacherous to exit without sinking, so calmer water the better. Some do run bays, rivers, creeks etc. with not still water, however, it will not fight a current with any speed nor is a chop preferable. An outboard will help a 9.9 is the highest recommended and after repairing a sunk machine which had a larger engine stand it up, and sink it, you should heed it.
    So imo trying the machine where you plan to ride it may be best, especially if the current owner who is familiar with the machine will take you, and in the water. YOU will get stuck, a ton more often now than later, but stuck in some versions of mud. We all do.
    Good luck.
  6. #6
    I have a small river to cross. About 50 ft across. We will try shooting an arrow with a rope on it to pull myself across as there is a bit of current. 15' deep. i do not have outboards but do have trolling motors. there used to be a bridge there 30 years ago, gone now. Lake on other side has big bass! hopefully this summer pics to come.
  7. #7
    Join Date
    Oct 2007
    Location
    Texas
    Posts
    2,161
    Please be careful crossing creeks, have seen many an experienced rider overcome with confidence and get swept away. Have only seen four machines completely sunk, most have been partially submerged and then pulled out. On the submerged machines we pulled plugs, blew the water out, changed oil and filter, gear oil, and all four came back to life.
    Water speed is hard to judge, anything flowing more than 1.5mph is potentially a hazard. The rope trick works as long as you can hold on to it. My advise is turn around don't drown. That applies to man and machine.
  8. #8
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Quote Originally Posted by Noel Woods View Post
    Well written. Experience conquers much, but not all.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
