I have a 750 HDi with a factory bush guard. Was wondering if anyone out there had any cool pictures of how they have been able to mount a chain saw at the front attached to the bush guard. If you do please share. Thanks.
Good afternoon Pike, try Kolpin, there description is a saw press for ATV. They do the gun boots and mounts also. kolpin-universal-saw-press-bracket.
Good luck, I dont know if the brush mount is the best location tho, mine is mounted on my custom top at the rear.
Thanks that is an idea, but I was thinking of something like the Saw Grip, has anyone tried anything like that hanging off the bush guard.
Rapidroy why don't you think the front is a good location?
Hey Pike, thats a good looking mount. Unless you can mount the saw where it will be protected from sweepers it will likely get damaged. The front is a handy place to have it, but it needs to be protected so it will be in useable condition when you need it most.
Not criticizing your choice of location, just making an observation. Good luck... R.R.
Hi Pike I agree with Rapid and Beagle you are asking for a bent bar or worse with the saw on the front.I run my HDI with a rack on the back,between the rack and the back of my machine I mounted my saw bracket on the rack.Two pcs 6in.x8in.1/8 steel with a pc of 3/4 rubber glued to ea.pc of steel one pc has 2 nuts welded to the outside wide enough to allow the saw blade to slide in. I then used to larger eye bolts to tighten saw blade into bracket.Body of saw is also cushioned by a pc of 3/4 rubber.I am trying to attach a pict. to give you an idea.
