Currently replacing all outer bearings on my 96 vanguard 2. Ordered all the bearings from buffalo bearing by doing research on this site and finding the appropriate part numbers. Well as it turns out the 2 front inner bearings are gone as well which is argo part #UC206A-20 if im not mistaken. The flange assemblies also seem to be worn pretty bad so i would like to replace them while im in there. Can anyone help me find the part numbers that buffalo bearing will need for these items? Any help is greatly appreciated!
UC206A-20 is a standard bearing part number so that's all you need. For the flanges, any bearing store should be able to get you the proper flanges without a part number. Just tell them the part number of the bearing or the diameter of the bearing, how many bolt holes it has and whether it is greaseable or not.
