need some help. I can turn to the right no problem but when I try to turn to the left it doesn't really turn, even if I pull hard on the steering and give it throttle. what's wrong?
What machine?
Camo side up, Rubber side down!!
2014 Argo 750HDI SE
2008 Honda Rubicon, Camo
2008 Jeep Rubicon, Black, 2 door, 6sp, 2 Warn winches.
If it has a tbar check the keeper/guide for the brake rods are not bent forward, if so the cylinders piston cannot fully refill, bend them straight and turn in lightly back and forth to bleed.
my argo is a 1993 magnum 8x8
Are there any brake pads left? Is the stick firm? Does machine or trans. make any noise when turning? Are you running tracks?
More info is better.
