Top for my Avenger done. Went with 1/2 top on this argo had a full top on my last one.
Nice looking setup you have. Any reason why you went with a half top after having a machine with full top?
—Will Rogers
Looks great! I like the safari rack on top. Nice job.
That looks really good.
I went with half top because when trailer is full of moose meat and you need to load more into argo, you don't have to muscle it through back door. Bad back. Much easier to load.
IMG_1161.jpgIMG_1162.jpgIMG_1164.jpgI have to plug Harbor Freight 7 ton pipe bender, worked fantastic when putting top together. Found that you need to go 1/2 inch undersize on die to get a good clean bend on pipe. The 2" brush rake in the front of the machine is one continuous piece to back, with one support welded in at front of door. Thanks Harbor Frt.
nice job nushagak,me likes that.great to see that meat being taken care of properly as well.
Did you make that top out of aluminum?
Tat, all aluminum....
Very cool! I can't weld aluminum. I have tried! Wasn't pretty.
