bigfoot 6x6 brakes
+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: bigfoot 6x6 brakes
  1. #1
    bigfoot 6x6 brakes
    first post, I've got a 6x6 bigfoot with 150hrs, that when you pull either brake lever it jumps back and forth. I pulled all of the covers off and noticed that the rotor is rusted up. going slow I can feel the rough spots on the rotor as they come in contact with the pads. I've thought of just using scotch bright pads to remove the rust? any thoughts?
  2. #2
    Join Date
    Jul 2009
    Location
    Cleveland,Oh.
    Posts
    1,589
    Welcome to 6x6world. Yes,cleaning the discs may be all that's necessary to smooth things out a bit. Keep us posted.
  3. #3
    Got home tonight and pulled the caliper off the right side and used a beartex pad to smooth it down. Put it back together and rode around a little. The brake is still kicking back and with it being dark I could see a few sparks coming out! When I had the caliper out looking down into it one side has a plate with a pad attached, the other is just a plate. Are both sides supposed to have the plate and pad?
  4. #4
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    Pads. I think your brake pads need replacing.
  5. #5
    Join Date
    May 2010
    Location
    Fairbanks AK
    Posts
    1,456
    Brake pads are a basicly square metal plate with two holes at corners for cotter pins. The friction material attached is about 5/16" thick when new. Sounds like worn out pads and the rotor may be ruined also. Rotor should be very smooth on both sides.
  6. #6
    [IMG][/IMG]
    Here is a picture of what I am talking about. Am I missing the left brake pad?
  7. #7
    Join Date
    Oct 2013
    Location
    Northern Alberta, Canada.
    Posts
    157
    Defiantly need new pads. One is good the other is worn right off. As mentioned your rotor may need turning or replacing too. Is the calliper seized or sticking? Sorry for your luck.
    Camo side up, Rubber side down!!
    2014 Argo 750HDI SE
    2008 Honda Rubicon, Camo
    2008 Jeep Rubicon, Black, 2 door, 6sp, 2 Warn winches.
  8. #8
    Well the other caliper looks the same so I'll change out both sets of pads, might be a good time to do the calipers also. Is the a preferred vender I should look at? Thanks for the help!
  9. #9
    Join Date
    Oct 2008
    Location
    Thornton, CO
    Posts
    646
    Don't buy new calipers unless there is a corrosion/breakage problem. Get the rebuild kit. There is really nothing to rebuilding these.
  10. #10
    Join Date
    Aug 2011
    Location
    Kotzebue, Alaska
    Posts
    1,209
    If there is no damage to the calipers then no need to replace them. Change out the pads.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
