Finally got to take the new unit for a rip. All I can say is wow... a tank. After running SxS for many moons. I took the plunge.. literally. I have couple questions and I'm sure as I navigate around the board here I'll find answers on other stuff I want to know but here it goes..
1. How much slack is normal in the tracks? I have all the metal connections still in and the dealer said I will "eventually" have to pull out the middle hinge as the tracks stretch a bit. IMO they are loose.
2. I went through some nasty skeg/water stuff on my first ride with not so much as a hiccup. What can I expect by pulling off my tracks in the summer as far as capabilities of the argo go? Will I be stuck way more? I'm asking this because I can see the tracks being a bit of a PITA to keep running good. ie. tire pressures, wear/tear, maintenance etc. and they don't swim well. I am also guessing the ride will improve on tires vs tracks.
3. I have the drop in boxliner. Anyone figure out a good gun mount or have a good picture of how they've done it? I'm not buying the argo one.
Thanks in advance
Cheers
