Hi folks - I have a 2000 conquest dead in the bush, the last of the teeth on the brake disk (left side) let go. I have a new replacement disk and will be going back up in a couple weeks to hopefully swap out.
My questions are - can anyone confirm for me what size hex/allen key I need to remove the brake assembly from the disk, and what size wrenches do I need to loosen the big bolt (112-57 HHCS 5/8-11x10.0 Gr5 Zc) that holds the transmission to the frame. Also - I suspect I will need to bring along a gear puller just in case.
Any info or ideas would be appreciated.
Thanks
Todd.
