Hello, I'm shortly picking up an 2003 Centaur. What is the best way to secure it on the trailer ? I guess the parkingbrake is not enough ? Can you tie it down by using the axels as securing point ?
I agree, use 4 corner axles. Keeps it from moving any direction. Use ratchet straps and girth hitch the axles. Ratchet strap hooks all have an eye that you can put the webbing back through. Do that on the strap end and then run it back to the ratchet end that's secured to your trailer. Makes for one less hook on each strap that can wiggle loose. You can girth hitch anything so you're not limited by the hook-size or trying to find something you can actually hook to.
