Here we go
+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 26
Thread: Here we go
  1. #11
    Join Date
    Sep 2008
    Location
    woodland pa
    Posts
    534
    Sorry half links are junk to be used only to get you home. Destroys sprockets and are a weak link in the system. Been there done that
  2. #12
    Join Date
    Nov 2009
    Location
    Charlotte, Mi/ Houghton Lake Mi
    Posts
    2,910
    Half links are bad because the machine was engineered (chain length calculated) without them. Putting one in has the same effect as a chain that is too long. It will max out the tensioner and become slack......Slack chains are BAD.
    If you absolutely had to....put in the half link with the intention of removing it as soon as possible.
  3. #13
    Join Date
    Jun 2014
    Location
    Smithfield N.C.
    Posts
    782
    B
  4. #14
  5. #15
    Join Date
    Sep 2008
    Location
    woodland pa
    Posts
    534
    I broke 6 of them sorry
  6. #16
  7. #17
    Join Date
    Mar 2010
    Location
    Oconee County, SC
    Posts
    823
    Glad you go the chains on. I can see the new larger sliders caused the problem you had.
  8. #18
    Join Date
    Sep 2008
    Location
    woodland pa
    Posts
    534
    I have had 1 problem since buying o ring chains and a lot of my problems could have been cheap chain which brusier would stretch in 5 minutes. And axle walk which caused miss alignment. Before I changed the attex from 6 to 4 I could not keep the middle axle from walking and I sheared 3 sprocket tubes in half and they did not walk. I have a pic of 1 I split in half in my pics. I also changed to max splined axles. I then had a sprocket hub walk. I then parked it and put on 2 piece split collars and have not had any problems. I did use cheap roller chain from tractor supply. I think model citizen and whipper would also know a lot more than me
    . And enjoy there input.
    I was wandering my half links were roller was theirs orings
    And who can argue with someone that jumps buses
  9. #19
    6x6burnout:
  10. #20
    Sorry Jeffrey I disagree and As Bridget mentioned them running them and no problems. Half links Aren't a Weak LINK! Ask any chain manufacturer! We sold Lots of combines and other machinery that uses lots of chains used under High stress and Shock loads and on most Old chains I've seen main roller links break before a master or a half link. And they all came from factory with half links in original chains. A half link is as Strong as the riveted roller links! If you breaking chains or sides are wearing you need to fix the problem or problems! Cheap chain and links are another story, as it wears- stretches quickly, and then causes excess wear on sprockets. Alignment, Worn sprockets & incorrect tension = chain failure. Hope you figure out the problem.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
