I am trying to add auxiliary lights to my 2000 Response. Where can I locate a switched power wire that only provides power when the ignition is on? I have a 40 amp alternator installed. Thanks in advance for any help!
Yes,but reailze that load goes thru the ign sw. Seems you have a pretty good grasp of schematics. I'd suggest just building a separate circuit to suit your needs . Use a relay,coil to that white wire (small load on ign sw contacts) batt to n/o contact on relay then to sw for your aux ltg. Aux lites will only work when ign sw is on and load will be on the relay contacts,that's their job.
