Avenger Throttle Replacement
+ Reply to Thread
Results 1 to 4 of 4
Thread: Avenger Throttle Replacement
  1. #1
    Hello guys,
    I was just wondering if it is normal with the forward play in the twist throttle? I just replaced the old as it was worn out and the new throttle has a lot of forward play. Any help would be greatly appreciated. Thanks.
  2. #2
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    You shouldn't have a lot of forward play. You should be able to adjust that out using the adjustment screws on the cable either at the throttle or at the engine either one.
  3. #3
    Hi Mike, thanks for the info. I will try that and I will let you know.
  4. #4
    Hello Mike,
    I did it and its a lot better. There is still a little play though. Thanks.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
