Conquest heater install pictures wanted
+ Reply to Thread
Results 1 to 5 of 5
Thread: Conquest heater install pictures wanted
  1. #1
    I am going to install a heater in my Conquest but as I am sure you have heard the install documents are not the best. Does anyone have pictures of where the heater unit actually goes and anything else you think is important for the install.
  2. #2
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    It will depend on which Conquest you have, some had the metal air intake and some had the plastic.
  3. #3
    I have the plastic intake.
  4. #4
  5. #5
    I started the heater install and figured out how to easily drain the radiator with out making a mess. I drilled a 1/8 hole where I was going to insert the T for the lower radiator hose, the hole sealed up after it was drilled. I inserted a small tube from one of those Harbor Freight hand pumps. I was able to pump all of the antifreeze out and pull the hose off of the lower radiator with out spilling any antifreeze, very clean with no mess.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
