Hello everyone,
Mainly a reader on the site but I do have some questions for the guys on here. I know that this issue has probably been mentioned in a bunch of posts and I did try to search for some of the info but I thought I would try to post some questions as I usually on read what others have said/done!
I have a 2005 avenger running 18" rubber tracks and have experienced some broken axles over the past year. The front axle just recently went on our moose hunting trip this past week. The damage/break was at the spline area and it looked like it twisted/sheared right at the splines.
Is this a common break?
The other axle went last year and it was the second axle from the front or #2. The damage to this axle between the bearings and was a clean break.
Both times this has happened the tracks have been on. I do not have the track tuners installed but I have tried to match tire pressures from front to back to assist with chain wind up. I will admit that I have not measured the tire circumference so this may lead to the problem.
The terrain we travel on is a mix of swamp and bog with rocky ridges. I keep the tracks on because we encounter more bog than ridges to get to hunting spots.
Has anyone else had issues with axles breaking when running tracks? Is there an issue with axle breaking and chain windup when the tracks are off? This machine is mainly used in the winter and then for a week or two in the fall for hunting but the tracks are always on.
The machine has 330 hours and still original axles before the break. As well, the chains and sprockets are original.
I am looking at a complete overhaul on the chains, sprockets, bearings and axles. I just want to make sure that there is no other issue to be concerned with like a twisted frame or some other misalignment issue before the overhaul begins.
Do you guys recommend going to the HD axles and bearings for the 05 Avenger?
