Hey,
I just finished changing a front drive chain as the previous one was loose. Figured while I had everything apart I would grease the spindle bearings and idler shaft bearings. Well even with the side grease gun fitting I had a hell of a time getting to the idler shaft bearings behind the brake disks......any tricks? Changing the chain was easy. Other note does the front drive shaft sprocket have set screws in it or is it a floating sprocket?
Thanks LT
