I pulled the left rear wheel because I felt a bit of play in it. The bearing is good, the bearing to axle is good, it the bearing is loose in the housing. I think the stamped steel retainer/ flange might be bent or worn. Maybe bent from a sharp impact. Does the aluminum housing on the outside usually need replacing?
