I have about 300 hours on The fronts and rears on my 99 conquest. I have not replaced one bearing so far. The only issue I have had was the pressed in grease fittings pulling out. I used a right angle grease gun adaptor to be able to grease with the tracks on. This may have caused the fittings to pull out. I have since removed, drilled and taped the housings to 1/8 npt and installed 90 degree grease nipples.
