Post a picture of where you are at now.
I will when I get home from school at 3
Here is pictures of the 19 and 24 tooth sprockets
I just ordered two front and two mid chain from Argo dealer that time,so what do I do with the other chsins
This should help from drivers area. Does yours look like this?
Notice the 24 teeth sprockets on 2nd axle on the outside, 1st axle on the inside.
This machine uses 42P chain on the fronts and 70P chain on the 2nds, 2nd to 3rd and 3rd to 4th axles are 19 tooth sprockets to 19 tooth with the chain having 96P.
This is the exact set up on mine!
My Argo has the 24 tooth on the inside,that's what's wrong i got it finally! Lol took this long to figure out that I had the speaker on the wrong end of the axle
I think the setup is different. The chains are on different sides then mine
Well then as stated run them the other way, as long as they match. There is a misprint in some of the Magnum catalogs.
So putting them inside or outside won't hurt anything?
