ARGO CONQUEST...8x8 with plastic tracks
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: ARGO CONQUEST...8x8 with plastic tracks
  1. #1
    2000 Argo Conquest
    220 hrs
    Plastic tracks
    Thinking about buying this thing. Seems to run ok. Tires have worn tread.
    Chains a little loose
    What's it worth?
    I think it's really clean for its age. It's been garaged and the tracks have not been run on the vehicle.
    I was going to buy new tires and install hd bearings and chains.
  2. #2
    By the sounds of it you have a very excellent machine that is worth a lot,buy it you won't ever regret a conquest
    P.s magnum owner here, lol get the thing sounds like a great rig
  3. #3
    Quote Originally Posted by curtisbyrne View Post
    Well I figure it is an ok machine. But just trying to get an idea on how much to offer the guy. I could run it like it is with some initial service and adjustments...but in the near future it would need tires, chains, bearings
  4. #4
    Join Date
    Jun 2007
    Location
    Ontario-Prince Edward County
    Posts
    997
    Quote Originally Posted by Hog Rush View Post
    The Conquest was a great machine. Lots of them are still running strong. You sound like you are prepared to replace bearings etc. Be aware that argo no longer stock kawasaki engine parts and some of our club members say its a bit frustrating to order them from a John Deere dealer who will only be able to look the part up if he knows which tractor or Kawi. Mule the are for.
  5. #5
    Quote Originally Posted by philipatmaxfour View Post
    If I get it...I will replace everything that's needed to make it reliable and better than factory. Maybe add a top and trolling motor
  6. #6
    Join Date
    Mar 2010
    Location
    Oconee County, SC
    Posts
    823
    2000 Argo Conquest
    220 hrs
    Plastic tracks
    What's it worth?
    The 2000 conquest came with 62mm bearings and the hdi are 72mm bearings. For you to convert you would need to order 8 ($87 ea.) of the kits from adair argo. check ebay for chain. 2x 10ft boxes of 50-2 chain and 2x 10ft boxes of 60-1 chain.
  7. #7
    That is if there is a bunch of stuff wring with it,if not we'll you really have a deal! But send some pics if you can and we can help you
  8. #8
    Quote Originally Posted by Dan67 View Post
    Thanks
    The ARGO is in great condition but has 3 loose wheel bearings and chains are dry. Tires are worn. Has super winch up front.
    I don't think it's hurt, but I'll replace all bearings and chains to upgraded parts and axles if I need to.
    Also...it has the medium range tranny or MU coded one.
    I just think this was taken out and garaged when not used and drive train was not serviced like it needed to be.
    Is it worth $4500 with tracks?
  9. #9
    Maybe like i said send some detailed pics of the engine Braking system so on
  10. #10
    Join Date
    May 2015
    Location
    Northern Alberta
    Posts
    159
    Just remember to take into account the cost of parts before you pull the trigger. I've put up the cost of my 97 conquest in parts now, doubling the total cost of it, and it's only been a couple months. The cheapest ebay chain you can get is about $450CAD shipped if I remember correctly and it's been said to only last about 50 hours. The Tsubaki chain is about double that cost but lasts 200 hours. Those hour numbers were given to me by a retired fella who had an argo for sale nearby and just loved talking about them. If your sprockets are warn and need replacing, that's somewhere around $1200 CAD including the brake rotors and idler shafts which need to be replaced as they have permanent sprockets. New tires was $1800CAD with rims, had to buy new rims because the old ones all leaked air out of the corroded and pitted beads. The topper you want is about $1400CAD. I decided not to bother with axle and bearing upgrades. I just bought a couple spare axles in case I break one. I figure it's simpler to just get the bearings and seals from my local bearing shop and just change them out as needed. I found I do not like running mine with the 18" plastic supertracks, it doesn't have enough power to do it without feeling like I'm killing it, and the drive-train doesn't feel rugged enough to handle the forces required to turn the machine on dirt with those things.
    My local dealership has been able to get every kawasaki part I've asked them for. Things like fuel pump, carb gaskets, pushrods, governor springs, throttle cable, etc. On second thought the fuel pump might be an argo part not kawi.
    Anyway not trying to discourage you here, just don't jump into it thinking "yeah it needs a little work but that stuff will probably just be a few hundred bucks"! We have a lot of fun on mine even though I've been put through the ringer spending every weekend in my garage with it lol.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
