I am trying to bring my Argo back to life after it died during deer season. I started trouble shooting and found the solenoid was bad by testing it with a voltmeter. Changed the solenoid and it wouldn't fire. Found a wire had come off the fuse block at the fire wall. Once I put it on it would fire with starting fluid but die immediately. Went through the fuel system and found the pump had a compromise diaphragm. A quick trip to the loca small engine shop and 25$ later it is firming up as soon as O turn the key. The problem is it dies as soon as I disengage the starter. It as if its losing fire when the key goes from start to run. I searched the threads and haven't found a similar post. Has anyone got any ideas where to check? I checked all other fuses and they are good. The engine is a 16hp vanguard.
