brake callipers
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: brake callipers
  1. #1
    brake callipers
    i am emoving the right side brake calliper of my argo becuase my dad took it for a trip last year not knowing the brake pads were gone on one side and the metal ate the rotor so i am trying to remove the calliper but i cant get the bottom bolt out even with vice grips latched on to the allen key.
  2. #2
    Join Date
    Mar 2010
    Location
    Oconee County, SC
    Posts
    823
    If it is like my conquest.. you have to jack up the machine. You will need to turn the tires in order to turn the rotor so that the hole in the rotor lines up with the bolt you need to remove. Use allen key socket to remove bolt and spacers if equiped. I do the top then the bottom bolt. Once the caliper is off just pull pins, drop out old pad. Spread the caliper open and insert new pad and clips. Then install back, easier to do the top first then the bottom bolt. Don't forget the spacers.
  3. #3
    yeah but the bolt wotn budge (bottom)
  4. #4
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Assuming you are turning the bolt the right way, left side up and right side down, you could use a small piece of pipe as a lever extension or take the cut off piece and put it in a socket.
  5. #5
    the vice grips spin on the allen key even when i have it tightned with all my might
  6. #6
    got the calliper of,boy what a mess now gettig rotor off? it wont come off becuase it is hooking up in the 24 tooth sproket below it
  7. #7
    Join Date
    Oct 2011
    Location
    Copper Center, Ak.
    Posts
    136
    Curtis you have to remove both primary chains to get the motor plate high enough to clear those lower sprockets. Don't forget to loosen the center bolt on the motor plate, failing to do so you risk bending the plate. If the plate is taco'ed it changes the shaft center distance between the trans and engine affecting how the belt performs in the clutches. That's some drama you do not want to deal with since you seem to being having too much fun already. Hang in there buddy and good luck... RR
  8. #8
    can i just raise the tranny and pry it up and pull the rotor off?
  9. #9
    Join Date
    Oct 2011
    Location
    Copper Center, Ak.
    Posts
    136
    You can't raise the tranny high enough without removing both primary drive chains
  10. #10
    Join Date
    Jun 2007
    Location
    Ontario-Prince Edward County
    Posts
    997
    Quote Originally Posted by curtisbyrne View Post
    Curtis, for the benefit of other people who may encounter the same problem, Can you tell us what you did to get the allen head bolt out from the bottom of your brake rotor. Good luck removing your chains and getting the rotor replaced.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
