Originally Posted by
Sparx
LX is only available in the HS trans, I would highly advise against this for any track system. The Escargo tracks do better then I thought with the STD trans, but I can't wait to get my HT (high torque) trans in due to the weight of these tracks. They take a bit to get up to speed in comparison to my previous HT Avenger with Rubber tracks. I really liked the HT trans, it accelerated fast and still gave me my top speed with the tracks on still. With the heavy Escargo tracks I feel the STD trans really struggle in the acceleration and high speed area but still turn in the thick good even in High range surprisingly without burning up the belt.
With the HS trans in the LX Avenger you would be stressing out the belt and clutching getting them really hot in anything but low range with tracks installed, even worse with a heavy track setup. You would be better off taking your chances if you did with a lighter plastic track setup like the Adair setup in that case but still have issues at low speed high loads in High Range. Plus you really have to be careful with tracks at high speed as they have to be set tight or they slap the tub pretty bad and you can have rubbing issues even with plastic tracks.
Do yourself a favour even though you could purchase the stereo separate, just install a bluetooth portable setup in your Argo and the USB/12V plugin yourself. I did this myself, even went as far as ordering a separate HT trans but I don't think you wanna go that route, it's ridiculously expensive.
If you really want the beadlock wheels just go with the Avenger STR and choose your trans in STD or HT. HS trans really is made for tire use only, I would get STD trans for tire and track use, and HT if the tracks are staying on all the time and being used in really heavy mud or swamp in High Range.
