Does anyone have the alternator kit on their Argo? I have the 750 hdi with the 30hp Kohler and Admiral trans. I opted not to get the alt kit due to numerous reviews saying it is a waste of money.
I have the following installed in addition to the winch and bilge pump that came on it:
Wet Sounds Stealth 10 sound bar
22" cree led light bar on front
two 4" cree led light pods pointing backwards on the back of the backrest
Six 12" led light strips for interior lighting
All of this is ran through relays and inline fuses, as well as tied into the fuse block on separate fuses so they each have their own fuse. I also wired it all through 5-pin lighted led rocker switches in the dash and the key has to be on for it all to work.
Now I'm curious to see if all of this is going to put a strain on my battery. I have turned everything on with the key on but the engine not running and it didn't change the voltmeter at all. I also did the same with the engine running/charging and everything worked and did not change brightness from idle through high revs and the voltage meter stayed up around 13.
Do I need to consider installing the alternator kit? Any concerns for pulling this much on the stock charging system? How much load can the stock charging system take?
Thanks in advance for your responses!
cdover73
