Front chains...
+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: Front chains...
  1. #21
    so not even just using one plate in the middle instead of two?
  2. #22
    Join Date
    Mar 2016
    Location
    Oshawa Ontario Canada
    Posts
    184
    No bro, i think it comes with 2 for a reason. It really wasnt any harder to get the second plate on, and you've already got the master in so it's just a matter of sliding it back to the middle, popping in the middle plate and then pushing it back into place. Shouldn't be too hard.
    "I've yet to encounter a problem that cannot be solved with the right mixture of whiskey and weaponry"
    :ME....
    " From my cold dead hands"
    :Charlton Heston...
  3. #23
    alright thanks kris,its just that my needle nose pliers would twist a little when holding the chain only making it easy to put one middle link in instead of two but i will fix this now while i have the top off!!
  4. #24
    Join Date
    Mar 2015
    Location
    Pickering, Ontario
    Posts
    633
    Quote Originally Posted by curtisbyrne View Post
    Use 2 nylon zip ties(one on each row) around the master to hold the chain together while you pop the keeper off and slip the 2nd plate in. Easy job. I use a flat head screw driver and a hammer to install and remove the keepers. tap it off, tap it on.
  5. #25
    Join Date
    Aug 2009
    Location
    Pincher Creek, Alberta
    Posts
    266
    Set the splice up so it ends on the top of a sprocket and it is a bit easier.. At least the few I've done.. Tyraps help.. When I fed the front ones around the sprocket, I used a piece of hay wire and fed that in first and had the new chain tied to it.. Then I made sure the front tire was able to be turned by hand to help line things up.. Let the air out and jack it up if needed...
    IMO.. If you want to leave the spacer plates out of a master link, then I'd make sure you pack two things with you when you head out.. A good pair of walking boots and a big lunch for when you break down.. Not IF but when.. You will be creating your own "weak link" (literally) and when it breaks you will have yourself to be mad at..
  6. #26
    Join Date
    Jun 2007
    Location
    Ontario-Prince Edward County
    Posts
    997
    front chains
    [QUOTE=glen1971;204326.-------------
    IMO.. If you want to leave ------- You will be creating your own "weak link" (literally) and when it br..[/QUOTE]
    that's funny
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
