Chain Options
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: Chain Options
  1. #11
    Join Date
    May 2015
    Location
    Northern Alberta
    Posts
    159
    I didn't realize that argo sold the tsubaki chain. Is 630 chain the same dimensions as the RC60-1 argo chain? I found that stuff here in O-ring: https://fortnine.ca/en/did-630-v-pro...l-o-ring-chain. I'm sure if I found it here there are ten places that have it in the US. O-ring RC50-2 doesn't seem to exist. Anyone ever tried to use 2 530 chains instead of one RC50-2? For a cool ~$2000 Canadian bucks you could have all o-ring chains if that's possible.
  2. #12
    Join Date
    Aug 2009
    Location
    Pincher Creek, Alberta
    Posts
    266
    Mine that I've replaced are from Napa and I just grabbed a box of single and double.. I had to change the front two, and kept the rest for spare.. That may be a winter project to go through and check them all out and make sure they are still in good shape and not over stretched...
  3. #13
    I just ordered this and am re-chaining now. I will let you know how it goes. It appears to be of reasonable quality. It ships from "Belarus Tractor International" So it must be some good Commie stuff straight off a T-34 in a field.
    #50-2 X 50FT Double Strand Roller Chain (Duplex)
  4. #14
    Join Date
    Apr 2014
    Location
    Ontario
    Posts
    20
    Argo has been using Tsubaki chain as standard offering on all new machines for almost 3 years now. Its good stuff.
  5. #15
    tractor supply has #50 and #60 chain, you can use 2 single #50 chains in place of the double #50, it fits perfect...and idk about you guys but i stopped using oring chain awhile ago, it serves no purpose other than making it a little quieter but even with oring , the chain noise is still annoying inside the cab....
  6. #16
    Join Date
    Aug 2009
    Location
    Posts
    266
    Quote Originally Posted by silvrbck View Post
    Why would you opt for 2 single 50's instead of one double 50? Don't know that it would be cheaper...
  7. #17
    tractor supply only sells singles in stock, ive been able to by bearings and chains anytime i need them right at my local TSC
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
