What to Do? Repair or Give Up
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
Thread: What to Do? Repair or Give Up
  1. #11
    Join Date
    Feb 2014
    Location
    Central Saskatchewan Canada
    Posts
    171
    If you are crossing a lot of dead fall a metal crosser will work better for you. If your main usage is pure bog or peanut butter mud Adairs have the edge. I assume you are in the USA, look to the Canadian track guys if price is the driving factor, you get around 30% off with the dollar and they sometimes have a sale in late winter. Another option is to buy a little more modern AATV that does not carry the huge price tag of new. Happy Hunting!!!
  2. #12
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    402
    If you feel comfortable with the reliability and performance of your machine after all your upgrades I would keep it and get either some adair or chanel tracks. These will outperform the supertracks by a wide margin especially in the swamp. If you do end up eventually upgrading to a newer machine both these tracks can be modified (lengthened or shortened) to fit that machine. I had supertracks and now run chanels and the durability and performance are not even close.
  3. #13
    Join Date
    Nov 2016
    Location
    Eastern Shore of Maryland
    Posts
    115
    Thanks to everyone for their help. I am going to stick with this current machine and order new tracks as soon as the holidays are over. I do need some minor welding work done (new shelf for the battery and some reinforcements for the front frame to protect everything from damage when using the winch). I am looking for a rubber headlight bezel (rectangular) for this 1989 Magnum 8x8 if anyone has one.
    Excited to finally have reached a decision.
  4. #14
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Just a thought for you to consider, member deedeelin has a Set of Adair's for sale in NC that would fit if you have 22's and his machine is 2002 or older.
  5. #15
    Join Date
    Nov 2016
    Location
    Posts
    115
    I decided to keep my Argo and ordered new tracks from Rick's Relics (TruTrax) and I couldn't be happier with them, or the transaction. I can recommend them to anyone. I am sorting through some performance issues including a significant sluggishness when I need power at the low end to turn or climb. It works fine in reverse, slightly less than ok in low, and poorly under strain in high. I am thinking fuel related or carb related. I also need to weld in a new battery pan and upgrade the supports on the front frame to handle the winch without tearing the tub. Super excited to complete everything and hit the swamps.
    Thanks for the great advice so far.
    Greg
  6. #16
    Hi your Argo is sluggish so keep in mind when you install tracks on your wheels your have added weight to the drive train. This extra weight will slow down an Argo. Rubber tracks are very heavy and this can cause loss of power. The drive train has to move the tracks you have to keep this in mind. Plastic tracks are not as bad.
    Hope this info is helpful. Paul
  7. #17
    Join Date
    Nov 2016
    Location
    Posts
    115
    A comment about tracks.
    We have been hunting the salt marshes and flooded pine forests of Southern Dorchester County in Maryland for almost 5 decades. Our first experience with amphibious vehicles was an Amphicat in the early 70's with just tires. We started using Argo's with Argo plastic tracks in the 80's. These tracks, either regular width or super tracks have been perfect for our area, which I would rank as pretty tough conditions of deadfall, pudding mud, 4-6' water crossings, rutted trails with stumps and humps, etc. There is a lot of chatter on here about the plastic tracks vs rubber tracks. For our purposes, the plastic tracks are spot on. I have no experience with the rubber tracks, nor have I ever seen them deployed and used in our area, so I cannot comment on how they do, but the plastic tracks do everything we need them to do and more.
  8. #18
    Join Date
    Nov 2016
    Location
    Posts
    115
    This isn't a sluggishness issue, it is a loss of power to the point of near stalling when putting the Argo under load (turning from a stop, etc.)
  9. #19
    [QUOTE=ARGOJIM;207958]Just a thought for you to consider, member deedeelin has a Set of Adair's for sale in NC that would fit if you have 22's and his machine is 2002 or older.[/ Epic Fail wrong thread
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
