crazy idea
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: crazy idea
  1. #1
    crazy idea
    would this work? using two flanges the same way the inner bearing is held in place but on the outside and without no flange. i would obviously have to get flanges with the grease zerk and use silicone and stuff around the axle. im trying to think of way that this wont work but i cant see why it wont.
  2. #2
    anyone??
  3. #3
    Join Date
    May 2009
    Location
    NJ 08533
    Posts
    5,052
    Max and other machines do just this.
  4. #4
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    Check out the bearing replacement video in the how-to section. I used a Max II and you can see the flanges/bearings.
  5. #5
    but would it actually work or would i be waisting my time doing this? would i have to use diff bearings?
  6. #6
    Join Date
    May 2007
    Location
    Kings Mountain, NC
    Posts
    7,788
    It would work but what are you trying to gain by doing this?
  7. #7
    i like the fact tht its just a bearing there and no worrying about seals failing. when a seal gets bad where do the water come in? also would it be less maintenance if i done the without seal setup?
  8. #8
    so.... if i used the proper flanges gaskets and some sealant i should have not worry about seals failing? i think i could save some money since i dont have to buy seals. i will do this as the old flanges and seals go since i have all new double sealed flanges on there now. also i know max uses lockin collars should i use them or just stick with set screw bearings without the collars? would the argo bearings leak?
  9. #9
    Couldn't I use just the flanges and bearing? No more grooves! Any input??
  10. #10
    Join Date
    Oct 2007
    Location
    statesville, north carolina
    Posts
    2,604
    Curtis. Your question has been answered 3 times in this thread. As mike suggested back on the 11th of may, Watch the video. Most of the manufacturers used the setup you are talking about.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
