Argo Frontier EFI 6x6 Base Model...or Upgrade to 'S' Model?
"Brand newbie" here to the world of 6x6 AATVs (...however I did pilot my first 6x6 in 1969...a yellow and white Scrambler with 7 h.p. and the steering wheel...out in the desert of SoCal...at the ripe old age of 9!) :rock:
I've been looking at new 2017 Argo Frontier EFI 6x6 models, and I've been looking at both the base model with the 19 h.p. Kohler and the 'S' model with the upgraded 23 h.p, Kohler, bearing extensions, brake cooling ducting, standard transmission, skid plate, bilge pump, and entry step. The 'S' model is an additional $2,500 more over the base model (locally offered at $8,999.) So there is my dilemma...which model and why?
So who and why would a new 6x6 enthusiast upgrade to the 'S' model with those additional features? :hmmmm2:
Is 4 more h.p., ducting for a future brake cooling fan, skid plate, bilge pump, side step, and bearing extensions on the four corner axles for $2,500...worth it?
My intended use here in Utah is general trail riding/exploring (4,200' to 10,000' ASL) and ham radio event support in both the desert and up in the Wasatch/Uinta mountain ranges...including winter trails...with my wife and our two dogs. No real plans to take it on the water. Yet since I've been told the Frontier steers by braking, the cooling fan/ducting seems like it makes sense for longevity. That, along with a skid plate, and a roll bar all make good safety sense to me. Other suggested enhancements, mods, options, or accessories? High altitude clutch tuning?
Appreciate your feedback! Thanks in advance,
Brad (denhabr)
KF6PSL
Sandy, Utah
1996 Ford Bronco XL 5.0/E4OD Pre-runner/Chase Truck
Reply to Tracks and Turbos...
Quote:
Originally Posted by
beagle man
Hey denhbr, I have tried just tires and also with Adair pro series tracks without the snow kit. Tires alone will spin out even on a packed trail and you will forever ( it seems) get sucked off the side of the trail, side note some places do not permit wheeled machines on groomed trails. The tracks where better but didn't really have a descent bite on the snow and would have done much better with the snow kit.
Thanks beagleman...understood, completely. I thought that the stock chevron 'paddles' on the Argo tires would be sufficient, but it makes sense. Like six billiard balls sliding on a hockey rink. :laugh:
thorn
Glad to see a fellow Utahan on here. I have run Argos here for 28 years and trust me when I say that if you can afford it get the upgrades. You will love the extra power up high and you will need to run at minimum the Argo standard track even on groomed trails. With just tires you can go in about 12" of loose snow. The EFI engines will help with the high altitude use for sure.
If you ever plan on wanting to get into serious snow travel you will also want to get the low 3.3 ratio transmission to pull bigger tracks. If you are mostly wanting to run on tires on dirt trails/sand then you want the standard ratio as the low will limit your speed to about 16 mph.
Hey thorn, thanks! OK, you are thinking what I am thinking...if you can afford the upgrades, do it now...and the tracks.
Also, do you know anything about the turbo kit that Western Skies Argo in Ogden is offering? It's made by OB Design based here in Utah, and supposedly provides a kit for the Vanguard motors that offers up to 10 lbs. of boost. At out Utah altitudes, that seems like the way to go!
OK on the transmission options...but I'm probably not going to venture off the beaten path anytime soon with ATV, so packed trails are going to be it for me. :snow: Are putting tracks on an Argo a real PITA? A few hours to complete the task, or is more like :30 minutes?
Thanks to all, and have a happy and safe Memorial Day weekend!
