Argo started bit slow this morning but it started went for a 30min ride came back shut her off and went to start and the battery is dead just enough to crank the engine over a bit. after trying to pull start many times i gave up. the battery showed 11V and i think the 30amp charge wire fuse was blown(i pulled it out but the other end stayed in so i dont know if it was or not but thats what i was expecting since it wasnt charging)so i replaced it turned the key and fuse blew again? all 15amp fuses are good and no wires were melted or messed up. what is the problem here?
