Sealing bolts after removing entry steps
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Sealing bolts after removing entry steps
  1. #1
    I had asked Fox Valley Argo (on another thread) how they sealed the holes after removing the Argo entry steps for a track installation. No response on that.
    I have a Frontier Scout 6x6 which comes with the steps from the factory.
    What is the best method of sealing the holes when these are removed?
    In addition, the position of he steps appear to be well below where the track would be (based on watching a million YouTube videos...)
    My 2nd question would be why the steps have to be removed in the first place?
    There seems to be plenty of clearance for a track.
    I do not have tracks yet but may add them at some point.
    Thanks for any insight on this!
  2. #2
    Join Date
    Feb 2016
    Location
    Mississippi
    Posts
    1,108
    Without knowing more, if I had a bolt hole in my tub and I wanted to seal it, I would just put a bolt in the hole with a flat washer on each side with a little dab of silicone to seal the washers.
  3. #3
    Join Date
    Jul 2009
    Location
    Cleveland,Oh.
    Posts
    1,589
    Not sure if my idea would be the "best" way but, I would do just as dirtdobber said. I've done this numerous times on my Argo.
  4. #4
    Okay, thanks! I had the idea of using the bolts to plug the holes...I didn't know if there was a superior sealant to use rather than silicone...hmmm...maybe that flex-seal stuff? They sell it at my local home store.
  5. #5
    Join Date
    Sep 2010
    Location
    rhode island
    Posts
    709
    Phil Swift here shamelessly pushing my flex tape. Have you seen the boat I supposedly cut in half and then taped back together?
  6. #6
    Quote Originally Posted by trevorakm1 View Post
    Lol...that's the stuff!
  7. #7
    Join Date
    Jun 2007
    Location
    Ontario-Prince Edward County
    Posts
    997
    ------after removing entry steps
    Quote Originally Posted by mowbizz View Post
    Yes! I think your question # 2 is a very very good question. Lets get that answered by Fox Argo or Adair Argo or Argo Jim or another expert before going in a direction that is not necessary.
  8. #8
    Join Date
    Mar 2010
    Location
    innisfil,ontario
    Posts
    1,430
    I'm thinking that the entry step might be kind of useless with the tracks and extensions on.unless your knee bends backwards of course,lol.suddenly that step is way to far inboard.
  9. #9
    Join Date
    Feb 2013
    Location
    shenendoah valley,va.
    Posts
    2,631
    the bolt and washers are a good idea...under each flat metal washer ( fender washers are best ) put a rubber washer and the silicone then. the rubber washers are usually in the plumbing section of the hardware store..... have fun, johnboy va.
  10. #10
    Join Date
    Jun 2007
    Location
    Posts
    997
    Quote Originally Posted by plott hound View Post
    Hi Plott hound. You are right for sure that the steps on my Avenger are useless and out of sight when my rubber tracks are on . but I don,t think there is any reason to remove them. What do you think/
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
